Simple Motorcycle Flasher unit
Postby Shep » Mon Jun 04, 2012 7:48 pm
I've used the search function but not found anything on the board yet so can some one tell me if this circuit,
http://www.circuitstoday.com/simplest-l ... er-circuit
Would be strong enough to replace the flasher unit in my Motorcycle which at present uses 12v- 2x21w standard bulbs per each side.I tire of the shop bought old style bi-metallic ones and a solid state one only lasted a year so the quality around is not that good.I'd rather build my own.Can the above be made more heavy duty with different value components if required?
Thanks for any help :)
Shep
Re: Simple Motorcycle Flasher unit
Postby I_Daniel » Wed Jun 06, 2012 1:14 pm
Check if the contacts of the relay can handle the amps. To be on the safe side 10 Amps should be okay.
Do your calculations on the resistance of the bulb and 14.7 Volt which would normally be the voltage while the motorcycle is running and charging the battery. This means the worst case consumption of the 21 Watt globe is almost 25 Watt.
Postby Shep » Wed Jun 06, 2012 1:30 pm
Thanks for the reply.Yes it may be underpowered.
Can I use and how would I wire this?
[img]http://i42.photobucket.com/albums/e315/sheppola/Lazarus/Flasher-simple.jpg[/img]
[img]http://i42.photobucket.com/albums/e315/sheppola/Lazarus/Relay1.jpg[/img]
[img]http://i42.photobucket.com/albums/e315/sheppola/Lazarus/Relay2.jpg[/img]
Shep
$64.95
$82.88
Used INTEL Xeon W3690 Processor CPU 3.46GHz 12M 6.40GT/s pictureIntel Xeon E5-2650 V3 2.3GHz 10-Core LGA 2011-3 Server CPU Processor
$16.99
Intel Xeon E5-2650 V3 2.3GHz 10-Core LGA 2011-3 Server CPU Processor picture1PCS Intel Xeon E5-2697V3 Genuine CPU 2.6 GHz 14-core 28-thread SR1XF
$290.00
1PCS Intel Xeon E5-2697V3 Genuine CPU 2.6 GHz 14-core 28-thread SR1XF picture
