Circuit needed for smooth alternating 220V flasher
Postby landriesse » Mon Mar 11, 2013 8:53 am
I need a circuit to control two 220V bulbs that are flashing alternating very smoothly, e.g. a cyclus time of 30 seconds. At T=0s, bulb 1 is off and bulb 2 is on, and in the next 15 seconds bulb 1 gradually lights up while bulb 2 dims slowly. At T=15s, bulb 1 is on and bulb 2 is off, and the inverse happens until T=30s.
I assume the basis for this circuit is the Smooth Flasher by Burkhard Kainka (http://www.extremecircuits.net/2010/05/ ... agram.html), but what lacks is the second light connection and the feature to control 220V instead of LEDs.
Can anyone help me?
Lourens
landriesse
Re: Circuit needed for smooth alternating 220V flasher
Postby JoshMac » Sun Apr 21, 2013 3:36 am
Do they have to be 220v globes? or can you swap them out for some LED's?
JoshMac
Postby landriesse » Mon Apr 22, 2013 7:27 am
Thanks for your response, Josh
Yes, it needs to be 220V to control several spots.
Problem is already solved, as I purchased the Botex Dimmer DC-4P-G Schuko (http://www.musicstore.com/en_EN/EUR/Lig ... 003743-000)
landriesse
Flowserve NT3000 Transducer NT3002102SN1W00 XL Series Valve Positioner 4-20mA
$1499.00
 Flowserve NT3000 Transducer NT3002102SN1W00 XL Series Valve Positioner 4-20mA pictureSonoScape C611 Micro-Curved Array Ultrasound Transducer 8.0-4.0 MHZ
$299.99
SonoScape C611 Micro-Curved Array Ultrasound Transducer 8.0-4.0 MHZ picturePHILIPS C10-3V ENDOCAVITY COMPACT TRANSDUCER PROBE FOR PARTS OR REPAIR
$580.00
PHILIPS C10-3V ENDOCAVITY COMPACT TRANSDUCER PROBE FOR PARTS OR REPAIR picture2013 GE 6T ENDOSCOPE ULTRASOUND TRANSDUCER PROBE KN100092 47 FOR PARTS O REPAIR
$700.00
2013 GE 6T ENDOSCOPE ULTRASOUND TRANSDUCER PROBE KN100092 47 FOR PARTS O REPAIR picture
