Solenoid Alarm Clock in Series -- Voltage Problems
Postby EDDGroupAlpha » Thu May 09, 2013 6:42 pm
We are trying to put a solenoid into series with an alarm clock, in order to go off when the voltage jumps from the alarm going off. However, the voltage varies too much and does not reach a high enough current to power the solenoid.
We used a multi-meter to measure out the range and goes at the highest to around 1.5V. The voltage varies with the pitch of the alarm. When the alarm is not going off, the solenoid is not active. We are actually on an ac voltage, but the Alarm Clock is converting the ac current.
We are looking into this, but it is more than a little confusing. We were thinking that we could amplify the signal, and then use a diode, to keep it from exceeding the max the Solenoid can take (5V).
Transistor as An Amplifier (links)
http://www.st-andrews.ac.uk/~www_pa/Sco ... page1.html
The datasheet for the solenoid can be found here.
https://www.sparkfun.com/products/11015
[b]***Any information on how we could attempt to fix this would be appreciated and all used information will be cited along with relevant posts. ***[/b]
EDDGroupAlpha
AlphaSmart NEO 2 Portable Word Processor Keyboard - Tested Working pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureOtis Pulse PLC Processor Module Industrial Automation Blue
$320.00
Otis Pulse PLC Processor Module Industrial Automation Blue pictureNew in Box Notifier FSB-200 Detector
$499.99
New in Box Notifier FSB-200 Detector picture
