permanent magnet dc motor reversing control Help!!!
Postby countrybill » Wed Jul 10, 2013 2:39 am
Greetings, I suppose I know about enough about electronics to be dangerous! I am 72 years old, can remember when they invented the transistor! I have built a lot of machinery and controls, machinist being my main occupation for 40 years. I am retired but have a small shop and have always been good at building devices with electronic controls, etc. but just with relays and microswitches. I have a machine I have been building for some time, and am wanting to go from a 1/5 hp ac gearmotor to a 1/4 hp permanent magnet dc motor. I do NOT need speed control, just forward and reverse. I would like to use the switcher I have been using which has a center off and when you step down on one side it runs forward, let up on it it shuts off, step down on the other side, it reverses. I would like it to be simple and dirty. I know little about SCRs , triacs, or thyrisistors, and need some help in getting me going simply, off, forward, reverse, no magic stuff at all, but need help. I just bet some of you folks know exactly what I need. Thanks Bill
countrybill
Re: permanent magnet dc motor reversing control Help!!!
Postby pebe » Thu Jul 11, 2013 12:31 pm
What voltages are the AC and DC motors? Also, could you provide any more details on the switcher you have been using?
$27.04
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$365.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves picture55 LB Electric Lift Magnet Electromagnet Solenoid Holding 57mm Robotics 12v 24v
$17.50
55 LB Electric Lift Magnet Electromagnet Solenoid Holding 57mm Robotics 12v 24v picture
