Need help please :(
Need help please :(
Postby HanisPF » Mon Sep 02, 2013 10:03 am
Can anybody explain me how does this circuit works ?
im using this circuit for my project. but i dont know how to explain it :(
HanisPF
Re: Need help please :(
Postby pebe » Wed Sep 04, 2013 4:21 pm
Both 555s are wired to run as oscillators. There is a connection with no number against it – it is pin2.
With the maximum value of R shown the first 555 runs at 1cycle every 3secs. T=1.4 x .047 x 47 (in megohms and microfarads). The output is a 5Vpp near-triangular waveform at pin6 which varies (with a 15V supply) from 5V to 10V.
That waveform is fed to pin 5 of the second 555 and is used to vary its frequency. With pin5 at 10V the frequency is the normal one calculated as in the first one. F = 1/1.4 x 0.1 x 0.1 = 70Hz. As the voltage on pin5 falls the frequency increases.
So the output from pin3 will be like siren where the frequency goes from 70Hz up to a higher frequency and back down again every 3 secs.
I hope that explains well enough. If not just shout.
$99.99
$99.75
Multifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook pictureVWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card
$59.40
VWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card pictureDoorking 1835-010 Board with Display and Memory Chip Included
$700.00
Doorking 1835-010 Board with Display and Memory Chip Included picture
