No Transformer Pure Sine Wave Inverter
Postby boyntonstu » Fri Sep 13, 2013 2:58 pm
This project is for back up power during electrical outages.
I have been able to obtain and renew 100 Ah LA batteries.
I use a capacitor charger and I can charge a battery string up to the peak AC voltage.
I would like to invert the output of a series string of 13 batteries to 115 VAC.
In another forum I read this advice but their server is always busy so I came here for help.
If you can help me get on the path from the following words to a circuit and parts recommendation, it would be greatly appreciated.
High Power Inverter Suggestions
You came to the right guy. This is what I do for a living, I design power inverters in the 100 watt up to 10KW power level. In this case you have two good choices for H-Bridge switches: 1) Power MOSFETs, and 2) IGBTs. Either would work well, and for the MOSFETs, you may need to parallel a few for each leg of the H-Bridge whereas for IGBTs, usually one will do for each of the 4 switches. You would not use a D/A converter as such, you would use PWM (Pulse-width modulation) from an analog chip or from a DSP. However, a 240 VDC source is not enough for transformerless operation. You need 240V*Sqrt[2] = 339V and that really isn't enough to compensate for drops in the circuit. You really need about 375 VDC to make a 240 VAC Sine wave from a PWM circuit. You'll also need an output LC filter to remove the switching frequency and the best choice is usually about 20 KHz to 25 KHz. This type of design requires the best breadboarding technique. Actually, I wouldn't make it without a PC Board for at least the most critical parts of the circuit, which are the gate drive and the power H-Bridge layout.
Gate drive, for either a MOSFET or IGBT are both very similar and it requires the proper drive circuit. You can't just drive it from the logic or DSP output. If you reallly are set on building this, then I highly recommend the IR2110 half-bridge gate driver. For a full H-Bridge, you'll need two of them and a 12V to 15V DC supply to run the chips. It's critical to keep the layout as short as possible and you must use a series gate drive resistor between each Drive output from the 2110's and the gates that they drive (that's 4 equal valued resistors of between 10 Ohms and 50 Ohms each). These help prevent ringing in the drain (FET) or Collector (IGBT) circuit. Selecting the proper MOSFETs or IGBTs is also critical. Use a breakdown voltage of at least 500 VDC to 600 VDC. THe battery power supply must be well bypassed as close to each 1/2-bridge section as possible between the upper fet drain and the lower fet source or its equivalent for an IGBT. You'll need a fairly high value low esr aluminum electrolytic cap in parallel with a couple of polypropylene film caps of at least 500 VDC each. One at about 2.2uF and another at about 0.47uF, both in parallel with a 10,000uF to 20,000uF, 500VDC Low ESR aluminum elytic cap for bulk storage. The impedance coming out of the batteries is way too high to use directly with the H-Bridge without all the bypassing I just discussed above.
Don't forget safety! It is critical to keep in mind that the potentials you'll be working with are very lethal and won't give you a second chance if you put your body across the 375VDC supply. Always use a fuse in series with the battery positive. For a 20A RMS output, your battery drain will be in the area of about 20ADC or a bit above, so use a 25A to 30A fast-blow fuse, or better yet, a superfast blow semiconductor type fuse. This may save you a lot of money on blown FETs and drivers, and may save your life as well. Be sure to put test points on your breadboard or PWB for easy hookup of scopes and DVMs. This is also a good safety practice.
Be sure and read the manufacturer's datasheets completely for the FETs, IGBTs, Gate Driver ICs, etc and do not exceed their ratings. In fact, make sure you have at least a 20% derating below the breakdown voltage and below the max current ratings, the derating should be more like 50%.
Good luck and reply if you have any specific questions for me.
boyntonstu
Re: No Transformer Pure Sine Wave Inverter
Postby pebe » Fri Sep 13, 2013 6:19 pm
I found this with Google. It may help.
http://homemadecircuitsandschematics.bl ... erter.html
Postby boyntonstu » Fri Sep 13, 2013 11:56 pm
[quote="pebe"]I found this with Google. It may help.
http://homemadecircuitsandschematics.bl ... erter.html[/quote]
Thanks for your search and the find.
I appreciate your efforts.
Presently I have an APC 2200XL Smart UPS 1750 Watt PSW.
It runs on 48 Volts.
If I could run it at 60 Volts using an extra battery, the run time and the current would be 20% better.
Do you know haw far above 48 Volts it could be programmed or hacked to function?
You may find this multimeter hack useful:
[url]http://youtu.be/6jCkRunDE3c[/url]
boyntonstu
12 Pieces 10A10 10 Amp 1000V 10A 1KV Axial Rectifier Diode solar panel C16
$5.49
12 Pieces 10A10 10 Amp 1000V 10A 1KV Axial Rectifier Diode solar panel C16 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V
$11.95
4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$18.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture
