Precision Rectifier Circuit
Postby kengwapo » Mon Sep 30, 2013 4:28 pm
Please help me with this circuit (attached).
What is the flow of current in this circuit? My problem is when i use 1/4watt, 5watts, and even 10watts for 10kohms and 12kohms (i used resistors instead of potentiometers) the circuit damages these resistors.. Can somebody help me? Thanks in advance! :D
Precision Rectifier
kengwapo
Re: Precision Rectifier Circuit
Postby pebe » Tue Oct 01, 2013 2:00 pm
I assume the 1A current source is 1A RMS at 60Hz. That current is going through a 3.3ohm resistor and gives 3.3VRMS across R3. There is no way that voltage applied across either fixed resistor would cause heating problems.
So I don’t understand the problem. Presumably this circuit is being fed into a simulator? Is the simulator saying there would be a fault?
WATTS 1"& 3/4" Dielectric Insulated Unions 21 pcs.
$95.00
WATTS 1Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L pictureBiddle Cat No: 220120 DC Dielectric Test Set 120Kv
$1650.00
Biddle Cat No: 220120 DC Dielectric Test Set 120Kv pictureSalisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel picture
