needing help with a circuit
Postby hthuecks » Thu Jan 16, 2014 11:16 pm
I'm trying to make a circuit that runs a dc motor (6volt) for about 3-5 seconds in a forward position stop and then 3-5 seconds in a reverse position. Then start back up in 60seconds to start the cycle all over again, until I turn the circuit of with a switch. Looking for it to run for about 3-5 hours. Thanks hope to hear from someone soon.
hthuecks
Re: needing help with a circuit
Postby pebe » Sat Jan 18, 2014 11:08 am
Do the forwards and reverse times have to be accurately matched?
Postby hthuecks » Sat Jan 18, 2014 8:43 pm
No they don't but it just has to move forward for a few seconds and then reverse for a few seconds
hthuecks
Postby pebe » Sun Jan 19, 2014 11:40 am
A suitable circuit would use, mainly, 2 x ICs, 2 x relays, and 2 x transistors.
Could you make it up OK?
Postby hthuecks » Mon Jan 20, 2014 3:57 pm
I have never done anything like this and have no idea what anything is. If you could draw me up a circuit I could have someone make me one I guess.
Thanks and hope to hear from you soon.
hthuecks
Postby pebe » Mon Jan 20, 2014 4:08 pm
Do you know someone who could program a PIC microcontroller for you if I gave you the program? That would do a much better job.
If not I'll draw up a circuit for you.
Postby hthuecks » Mon Jan 20, 2014 11:30 pm
how small of a circuit can you make me?
hthuecks
Postby hthuecks » Mon Jan 20, 2014 11:35 pm
No I don't no anyone that can program that pic microcontroller.
hthuecks
Postby pebe » Tue Jan 21, 2014 3:57 pm
OK. Here is a suitable circuit. You should be able to make it up on about 40mm x 40mm of stripboard.
The CD4017 is a CMOS device so don't solder on to it directly - use an 16pin IC holder and leave all unused pins unconnected.
Ideally, use a tantalum bead type for the 10µF capacitor.
Best of luck
Postby hthuecks » Thu Jan 23, 2014 8:17 pm
Hey pebe can this circuit run a 3volt watch battery, also could I put a diode or a dial in to slow the motor down due to the rpms. Also thinking if the times can be changed from 4sec forward and reverse to maybe 1sec forward and reverse.
hthuecks
Postby pebe » Fri Jan 24, 2014 10:19 am
The circuit will not run on a 3V watch battery because the 555 requires at least a 4.5V supply. Also there is not enough energy in a watch battery to run a motor.
Putting a resistor in series with a motor will reduce its speed but will not control it. You would need pulse width modulation for it to be effective.
The 470K resistor connected to pins2, 6, and 7 of the 555 controls the motor run time. A value of 100K would be about right for a 1sec run.
Postby hthuecks » Sat Jan 25, 2014 10:33 pm
Where can I purchase this stuff, and who do you recommend to make this for me?
hthuecks
Postby pebe » Sun Jan 26, 2014 12:45 pm
I live in the UK and get stuff from here. 1st class service.
http://www.bitsbox.co.uk/
I don't know where you live so cannot suggest anyone local to you.
I thought you were going to get someone to make it up.
I don't know of anyone who can, but maybe a member here may be able to help you
$7.77
‌USB Tester Type-C PD Digital Capacity Meter 8A Voltage Current Monitor Power pictureICM Controls ICM455 Three Phase Line Voltage Monitor Meter Test Device
ICM Controls ICM455 Three Phase Line Voltage Monitor Meter Test Device pictureMacurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureTenma 72-5082 Universal Test Center Multimeter/ Tested, Works
$237.49
Tenma 72-5082 Universal Test Center Multimeter/ Tested, Works picture
