Need help simplifying circuit
Postby geryuuu » Tue Feb 25, 2014 3:50 am
need help figuring out how to simplify
Need help figuring out a more simplified version.Im just having trouble figuring out whats parallel and in series
geryuuu
Re: Need help simplifying circuit
Postby geryuuu » Tue Feb 25, 2014 5:25 pm
I can figure most of it out, I just don't know how to write down R5, I believe it is parallel to both R6 and R4. Not 100% though
geryuuu
Postby pebe » Wed Feb 26, 2014 1:48 pm
If you want to simplify between two nodes, where are they?
Postby geryuuu » Fri Feb 28, 2014 5:51 pm
between a node centered between (r5 and r6) and (r5 and r4).
geryuuu
Postby pebe » Sat Mar 01, 2014 5:25 pm
Are not those points on the same top line?
Users browsing this forum: Majestic-12 [Bot] and 0 guests
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  picture1PC New Rectifier Brake module rectifier ESD138B 110-115 VAC 50-60HZ ESD-138B
$175.56
1PC New Rectifier Brake module rectifier ESD138B 110-115 VAC 50-60HZ ESD-138B pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture
