How to check the parts of a plaque.
Postby George1000 » Sat Nov 01, 2014 6:47 pm
How can I check the electronic parts of a plaque? I can't disconnect each one of them, check it and reconnect it because they are too much. Thanks.
George1000
Re: How to check the parts of a plaque.
Postby KMoffett » Mon Nov 03, 2014 9:40 pm
What kind of a "plaque"? Need a lot more info!
Postby George1000 » Tue Nov 04, 2014 6:44 pm
I mean something like that, sorry for not explaining but I don't know English very well.
George1000
Postby KMoffett » Tue Nov 04, 2014 8:53 pm
Short answer is: You can't!
Long answer is: Without knowledge of the circuit, proper test equipment, a surface mount rework station, and a lot of luck...you can't!
Postby George1000 » Thu Nov 06, 2014 4:25 pm
Well, never mind. Thanks.
George1000
$5.99
$6.47
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 pictureAllen Bradley 800T-U41 30.5mm Potentiometer Unit, 50 Kilohms Resistive Element
Allen Bradley 800T-U41  30.5mm Potentiometer Unit, 50 Kilohms Resistive Element picture
