Help with circuit for DIY Infrared Facetracking rig?
Postby kwmcken » Sun Nov 23, 2014 12:05 am
I'm making a facetracking rig for gaming (Similar to a TrackIR) using infrared LEDs. I put together my circuit to test before I soldered it all together, and lo and behold the LEDs are not lighting.
This is what the circuit looks like outside it's casing, can anyone give me some insight as to what I did wrong?
[url]http://i.imgur.com/M7EjFR6.jpg[/url]
Also- I checked to see if the LEDs were lighting with a phone camera, so not being able to see the light is not the issue.
kwmcken
Re: Help with circuit for DIY Infrared Facetracking rig?
Postby pebe » Sun Nov 23, 2014 1:46 am
The centre LED is wired the wrong way round. The flat on the side of the base indicates its cathode wire and should be connected to the negative pole of the battery.
Postby kwmcken » Sun Nov 23, 2014 3:57 pm
[quote="pebe"]The centre LED is wired the wrong way round. The flat on the side of the base indicates its cathode wire and should be connected to the negative pole of the battery.[/quote]
Thank you! However, wouldn't the others still light up even if the middle one was backwards?
kwmcken
Postby pebe » Sun Nov 23, 2014 8:49 pm
Maybe, but it's difficult to see from your pic whether the other two are wired correctly.
I cannot make out the color code of the resistors, either. What value are they?
Can you measure the battery voltage, and the voltage across each of the IR LEDs? That will help to find out what the problem is.
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureAllen Bradley 800T-U41 30.5mm Potentiometer Unit, 50 Kilohms Resistive Element
Allen Bradley 800T-U41  30.5mm Potentiometer Unit, 50 Kilohms Resistive Element pictureClarostat RA30 LASB 100 OHM Wirewound Industrial POT
$14.95
Clarostat RA30 LASB 100 OHM Wirewound Industrial POT picture
