How do i use two optical sensors to switch the same switch.
Postby cyangrinmonk » Sat Oct 31, 2015 7:31 pm
i need to switch a switch on when one optical sensor sees dark, and then switch it off again when a second sensor sees dark.
I couldn't find anything helpful on the net, but that's probably because i'm an electronics novice and probably not using the right language when searching.
monk
cyangrinmonk
Re: How do i use two optical sensors to switch the same swit
Postby pebe » Sat Oct 31, 2015 7:51 pm
Have you thought about what sort of opto sensor you would want to use?
Postby cyangrinmonk » Sun Nov 01, 2015 2:48 pm
Hi Pebe,
i was looking at this one :
http://www.datasheetcatalog.com/datashe ... 1103.shtml
All the best,
monk
cyangrinmonk
Postby pebe » Sun Nov 01, 2015 5:50 pm
OK, cyan-------,
I'll draw up a suitable circuit for you in the next couple of days.
Postby pebe » Wed Nov 04, 2015 2:05 pm
I'm just about to draw up a circuit for you, and realized the opto couplers you suggested will not act as sensors in the way you want them to. I suggest using light dependant resistors (LDRs) instead, if you agree.
What voltage would you like to use to power the unit?
What sort of device do you want to switch on? Do you know how much current it requires?
Postby cyangrinmonk » Wed Nov 04, 2015 10:00 pm
Hi Pebe,
sorry i don't check in often been busy, thanks very much for your kind offer to draw up the circuit.
It won't require much power, probably switching no more than 7-10 watts with limits of 18V and 2A (my bench PSU max output).
I think before you put in the effort of drawing up the circuit i should do some testing to get exact power requirements.
Thanks again,
cyan.
cyangrinmonk
Postby cyangrinmonk » Wed Nov 04, 2015 10:27 pm
I've turned on reply notification now.
cyangrinmonk
Postby bwetman » Fri Nov 20, 2015 5:55 am
Optical and magnetic sensors are used to detect the presence, absence, or motion of an object.[img][http://m.eet.com/media/1075223/0307feat2fig1.gif/img]
bwetman
$1550.99
Brand NEW ABB DSQC639 3HAC025097-001 Motherboard US Free TAX pictureIce Maker Main Control Board w/ Indicator For Commercial Ice Machine Motherboard
$29.80
Ice Maker Main Control Board w/ Indicator For Commercial Ice Machine Motherboard pictureM093 Inductance Tester Motherboard Coil Tester Inductor Detector Repair Tool SP*
$6.99
M093 Inductance Tester Motherboard Coil Tester Inductor Detector Repair Tool SP* picturePcc 3300 v2 Part No: A054J968 CUMMINS CONTROLLER MOTHER BOARD
$499.99
Pcc 3300 v2 Part No: A054J968 CUMMINS CONTROLLER MOTHER BOARD picture
