Bluetooth? Screw that. I need USB
Postby nwh212 » Fri Feb 12, 2016 3:11 am
Hey anyone out there reading this. I am not extremely professional. I'm not really at ALL. I bought one of those Atari iPad Controllers about a year ago. I found it recently and undid it, getting out the parts. The thing is, it's set up to use bluetooth. I want to try and set it up to use for games on my computer through USB (I don't have a Bluetooth computer and don't want to buy a crummy little Bluetooth USB receiver)
http://i.imgur.com/BSct5n1.jpg <- this is an image of the circuit board
This is the board. I've highlighted everything I understand (like the buttons and power in/out wires) But what do I do to change it to USB out instead of Bluetooth out?
nwh212
Re: Bluetooth? Screw that. I need USB
Postby pebe » Fri Feb 12, 2016 9:10 am
There is nothing you can do about it.
And what's wrong with a 'crummy' cheap receiver - it will do the job.
Postby PradeepKumar » Fri Apr 29, 2016 6:15 am
You need to go for an alternative as it will not function as per your needs in this connectivity.
PradeepKumar
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt picturePROGRAMMA SVERKER 750 RELAY TEST UNIT - Ammeter Not Working
$1799.10
PROGRAMMA SVERKER 750 RELAY TEST UNIT - Ammeter Not Working pictureLot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter
$79.00
Lot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter pictureFCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES
$16.99
FCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES picture
