help to design a ciruit
Postby sakarneh91 » Thu Feb 11, 2016 3:59 pm
hi,
i have a tablet,aux cable and speaker.
i want to connect the tablet to speaker directly through the aux , so i cut the cable of the aux and i got three wires ( left speaker,right speaker,ground) and connected them with the terminals of the speakers ,but i got a low volume , how can i increase the volume please.
BR :)
sakarneh91
Re: help to design a ciruit
Postby KMoffett » Thu Feb 11, 2016 10:46 pm
The output of the tablet is for small speakers in headphones You need an amplifier between the tablet and the speakers.
Postby sakarneh91 » Fri Feb 12, 2016 7:23 pm
[quote="KMoffett"]The output of the tablet is for small speakers in headphones You need an amplifier between the tablet and the speakers.
Ken[/quote]
no for car speakers ,can you give the design of the circuit or the suitable type of ampilfier i should use :)
sakarneh91
Postby KMoffett » Sun Feb 14, 2016 2:20 am
Are you referring to speakers in a car, attached to the car's audio system, or speaker from a car?
What make/mdel is your tablet?
Postby KMoffett » Mon Feb 15, 2016 6:16 pm
Here is a small amp that should work for you. We got a bunch of them for a student lab: [url]http://www.amazon.com/dp/B007TUSXEY/ref=pe_385040_30332190_pe_175190_21431760_M3T1_ST1_dp_2[/url
It needs a wall wart for power. This is not the exact one we have, but Amazon lists it together with the amp: [url]http://www.amazon.com/JACKYLED-Power-Supply-Adapter-110V/dp/B006NTNGN0/ref=pd_bxgy_422_img_2?ie=UTF8&refRID=1X5NA0A4E0RMY1DGAXYE[/url]
Postby sakarneh91 » Thu Mar 10, 2016 6:43 am
[quote="KMoffett"]Are you referring to speakers in a car, attached to the car's audio system, or speaker from a car?
Ken[/quote]
yes i want to connect the tablet directly to the speakers of the car , the model of the tablet Panasonic FZ-A1
sakarneh91
Postby KMoffett » Thu Mar 10, 2016 2:43 pm
By connecting the iPad "directly to the speakers", do you want to also have the speakers disconnected from the car's audio system when you connect the iPad? You can't just parallel an iPad+amplifier to the car's speakers with the car's audio system still connected to them.
If the car's audio system has an FM radio, there is an alternative approach:
Google: iPad to car FM
Postby PradeepKumar » Tue Jun 07, 2016 6:11 am
You should make use of an amplifier. Or otherwise try to connect your tablet to the speaker through another single input cable.
PradeepKumar
$1.75
Vintage Theater Marquee Letters Numbers & Symbols 9Vintage Wood Retail Display Case w/ Glass Top Countertop & Tabletop
$375.00
Vintage Wood Retail Display Case w/ Glass Top Countertop & Tabletop pictureThermo Infrared Handheld Vintage Minolta Land Cyclops 330 Case/manual Tested
$165.00
Thermo Infrared Handheld Vintage Minolta Land Cyclops 330 Case/manual Tested pictureVintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer
$162.41
Vintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer picture
