Simple NiMh discharger
Postby unclearty » Thu Mar 06, 2014 6:57 pm
I want to be able to discharge a AAA NiMh battery..(individual cell) ..down to .9 volts at approx 150- 200 mah draw.
I was going to simply use a 2.7 ohm resistor with a 1N4001 diode..however, a friend said that this would not be accurate enough due to the diode...that the battery could drop to .7 volts. I'd like to keep this as simple (inexpensive) as possible. I'd ultimately like to make a number of them.
Any ideas as to how to accomplish this?
unclearty
GE Sensing Panametrics CRS-05-MB C-RS-401 PAIR Ultrasonic Flow Transducer
$600.00
GE Sensing Panametrics CRS-05-MB C-RS-401 PAIR Ultrasonic Flow Transducer  pictureNOS YORK 025 29583 000 TRANSDUCER 0 - 200 PSI B94
$169.99
NOS YORK  025 29583 000  TRANSDUCER 0 - 200 PSI   B94 pictureSiemens 545-208 Analog Output Pneumatic Transducer
$550.00
Siemens 545-208 Analog Output Pneumatic Transducer pictureTUF-2000B Ultrasonic Flow Meter Wall-Mount Liquid Flowmeter TS-2 TM-1 Transducer
$244.24
TUF-2000B Ultrasonic Flow Meter Wall-Mount Liquid Flowmeter TS-2 TM-1 Transducer picture
