making colloidal silver
Postby Frank bao » Tue Mar 05, 2013 1:04 pm
I have been making it for a year now and i want to be able to change polarities at the silver electrodes about every three to five minutes or so.presently have a 30volt dc power supply going to a current limiting circuit that keeps the current under 3ma. It males a good CS but oneside wears down faster thanthe other and guess Im a little lazy to keep cleaning and switching my wires around etc... can you help me with a circuit that will change polarities at the frequency mentioned above? Thank you for your help...
Frank bao
Re: making colloidal silver
Postby hapticz » Thu Mar 20, 2014 6:22 am
a simple 555 timer set as a 50/50 duty cycle flip flop at 3-5 minute (use a pot to adjust the time as needed) , that drives a relay with 2 pole double throw set of contacts should work.
hapticz
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$250.00
Johnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac pictureJohnson Controls EASYIO FW-08 WiFi BMS/BAS Controller - NEW
$129.99
Johnson Controls EASYIO FW-08 WiFi BMS/BAS Controller - NEW pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT picture
