making colloidal silver
Postby Frank bao » Tue Mar 05, 2013 1:04 pm
I have been making it for a year now and i want to be able to change polarities at the silver electrodes about every three to five minutes or so.presently have a 30volt dc power supply going to a current limiting circuit that keeps the current under 3ma. It males a good CS but oneside wears down faster thanthe other and guess Im a little lazy to keep cleaning and switching my wires around etc... can you help me with a circuit that will change polarities at the frequency mentioned above? Thank you for your help...
Frank bao
Re: making colloidal silver
Postby hapticz » Thu Mar 20, 2014 6:22 am
a simple 555 timer set as a 50/50 duty cycle flip flop at 3-5 minute (use a pot to adjust the time as needed) , that drives a relay with 2 pole double throw set of contacts should work.
hapticz
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureBelden 5200 ue 2 Conductor 16 AWG 428 feet.
$45.00
Belden 5200 ue  2 Conductor  16 AWG      428 feet. pictureCarol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID **100 ft.**
$109.74
Carol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID  **100 ft.**   pictureSouthwire Company 28827455 Electrical Wire
$114.99
Southwire Company 28827455 Electrical Wire picture
