multiple light circuits on mutliple breakers on one switch
Postby tcomo » Sat Dec 10, 2011 2:11 am
I have a store that has about 8 rows of 10 florescent light fixtures on about 5 seperate breakers. I would like to see if there is a way that I could tie them in together and use one switch. Some type of relay system or something like that?
tcomo
Re: multiple light circuits on mutliple breakers on one swit
Postby flipgary » Sun Apr 06, 2014 10:21 am
[quote]I have a store that has about 8 rows of 10 florescent light fixtures on about 5 separate breakers. I would like to see if there is a way that I could tie them in together and use one switch. Some type of relay system or something like that?[/quote]
Did you check to see if the circuit breakers in the panel need to be changed? Are they old or new?
flipgary
Postby flipgary » Mon Apr 07, 2014 9:17 am
You want to setup like a series circuit of some kind? You can put multiple breakers on one switch and if it's just low strength lights then it won't put much load on the circuit breakers. You might want to look into a switched relay controller.
flipgary
$1.80
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$17.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker
$19.95
4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker picture
