SDRAM problem
SDRAM problem
Postby Jane » Thu Dec 29, 2011 9:00 pm
From time to time I must repair an equipment that has its own BIOS, CPU and SDRAM
This SDRAM has 256MB together and consists of 4 SDRAM modules(IC).
Sometimes equipment does not work.Then there are several possibilities for that.
Faulty CPU or BIOS or SDRAM.
Is there a method how I can find out that SDRAM is faulty? If so which module of those 4 SDRAM modules might be faulty?
Each SDRAM module has 66-pin Plastic TSOP(II) and is soldered on PCB.
or what method shall I use to check that the processor sends some signals( e.g. address signal) to SDRAM?
Thank you for help
Jane
$5.99
$6.47
Cavitron power potentiometer for Gen 131, 132, 136, 137 pictureAllen Bradley 800T-U41 30.5mm Potentiometer Unit, 50 Kilohms Resistive Element
Allen Bradley 800T-U41  30.5mm Potentiometer Unit, 50 Kilohms Resistive Element picture
