SDRAM problem
SDRAM problem
Postby Jane » Thu Dec 29, 2011 9:00 pm
From time to time I must repair an equipment that has its own BIOS, CPU and SDRAM
This SDRAM has 256MB together and consists of 4 SDRAM modules(IC).
Sometimes equipment does not work.Then there are several possibilities for that.
Faulty CPU or BIOS or SDRAM.
Is there a method how I can find out that SDRAM is faulty? If so which module of those 4 SDRAM modules might be faulty?
Each SDRAM module has 66-pin Plastic TSOP(II) and is soldered on PCB.
or what method shall I use to check that the processor sends some signals( e.g. address signal) to SDRAM?
Thank you for help
Jane
Tektronix TR503 Tracking Generator and TM503 Power Mainframe
Tektronix TR503 Tracking Generator and TM503 Power Mainframe pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
$225.00
