Dual Channel DC power supply
Postby Julian Wong » Sat Jan 14, 2012 8:19 am
Hi,i really need help on how to design a dual channel DC power supply that fulfills the following specifications :
1) Operation - User selection between independent adjustment for positive and negative output voltage, and series tracking mode (slave channel tracks the master channel)
2) Output voltage amplitude : 0-20V± 5%
3) Current limit : 0 - 1.5A± 10%
4) Powered Directly from main supply
5) Indications of power on, constant voltage and constant current mode
I really hope you guys will be able to help me as i need to hand in my assignment by the end of this month,kinda short of time and hopefully you all will be able to provide me with a schematic to achieve the above specifications..thanks in advance =)
Julian Wong
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid
$75.00
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureParker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA pictureNEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY
$399.00
NEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY  picture
