Dual Channel DC power supply
Postby Julian Wong » Sat Jan 14, 2012 8:19 am
Hi,i really need help on how to design a dual channel DC power supply that fulfills the following specifications :
1) Operation - User selection between independent adjustment for positive and negative output voltage, and series tracking mode (slave channel tracks the master channel)
2) Output voltage amplitude : 0-20V± 5%
3) Current limit : 0 - 1.5A± 10%
4) Powered Directly from main supply
5) Indications of power on, constant voltage and constant current mode
I really hope you guys will be able to help me as i need to hand in my assignment by the end of this month,kinda short of time and hopefully you all will be able to provide me with a schematic to achieve the above specifications..thanks in advance =)
Julian Wong
$27.04
$13.63
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
