Ultrasonic generator/blaster Circuit help
Postby xalu » Sat Feb 11, 2012 7:06 pm
The attached schematic is for an ultrasonic generator, however it is a bit vauge on what its specs are.
I was wondering if anyone can tell me what output the frequency will be for the ultrasonic pulse...is it 60-80KHz? . I am looking for 40-50kHz ([url]http://en.wikipedia.org/wiki/Cell_disruption#Sonication[/url]). The purpose is for cellular sonication. If it isn't correct could you tell me how it could be modified? Please reference the part numbers, or I will have trouble understanding.
I am an amateur when it comes to electronics, so I could definitely use some help :)
Thanks!
xalu
Re: Ultrasonic generator/blaster Circuit help
Postby pebe » Tue Feb 21, 2012 5:47 pm
In the circuit, IC3 generates the pulse whose frequency is determined by the value of resistance between its pin7 and the 12V supply rail.
The complete circuit is for the production of five sequential frequencies. It is done by using IC1 as an oscillator to drive the 4017 decade counter that switches the pots VR2 to VR6 in turn to the 12V rail via the isolating diodes.
For your purposes, you should leave out IC1 and IC2 and all the pots, and connect a 100K pot between R5 and the supply rail.
You can use the tables at this site to check the frequeny.
http://www.bowdenshobbycircuits.info/555.htm
Postby xalu » Tue Feb 21, 2012 11:18 pm
Can this drive a transducer? So if I kept those in, I could tune the frequency?
xalu
Postby pebe » Wed Feb 22, 2012 3:40 am
[quote="xalu"]Can this drive a transducer? So if I kept those in, I could tune the frequency?[/quote]
The output transistors are powerful enough to drive a transducer.
The frequency is tuned by the 100K pot in series with R5 that I said you should fit.
We R Memory Keepers 71050-9 The Cinch Book Binding Tool Machine *NEW *FREESHIP
$99.99
We R Memory Keepers 71050-9 The Cinch Book Binding Tool Machine *NEW *FREESHIP pictureVWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card
$59.40
VWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card pictureMultifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook
$99.75
Multifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook pictureDoorking 1835-010 Board with Display and Memory Chip Included
$700.00
Doorking 1835-010 Board with Display and Memory Chip Included picture
