Ultrasonic generator/blaster Circuit help
Postby xalu » Sat Feb 11, 2012 7:06 pm
The attached schematic is for an ultrasonic generator, however it is a bit vauge on what its specs are.
I was wondering if anyone can tell me what output the frequency will be for the ultrasonic pulse...is it 60-80KHz? . I am looking for 40-50kHz ([url]http://en.wikipedia.org/wiki/Cell_disruption#Sonication[/url]). The purpose is for cellular sonication. If it isn't correct could you tell me how it could be modified? Please reference the part numbers, or I will have trouble understanding.
I am an amateur when it comes to electronics, so I could definitely use some help :)
Thanks!
xalu
Re: Ultrasonic generator/blaster Circuit help
Postby pebe » Tue Feb 21, 2012 5:47 pm
In the circuit, IC3 generates the pulse whose frequency is determined by the value of resistance between its pin7 and the 12V supply rail.
The complete circuit is for the production of five sequential frequencies. It is done by using IC1 as an oscillator to drive the 4017 decade counter that switches the pots VR2 to VR6 in turn to the 12V rail via the isolating diodes.
For your purposes, you should leave out IC1 and IC2 and all the pots, and connect a 100K pot between R5 and the supply rail.
You can use the tables at this site to check the frequeny.
http://www.bowdenshobbycircuits.info/555.htm
Postby xalu » Tue Feb 21, 2012 11:18 pm
Can this drive a transducer? So if I kept those in, I could tune the frequency?
xalu
Postby pebe » Wed Feb 22, 2012 3:40 am
[quote="xalu"]Can this drive a transducer? So if I kept those in, I could tune the frequency?[/quote]
The output transistors are powerful enough to drive a transducer.
The frequency is tuned by the 100K pot in series with R5 that I said you should fit.
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1
$35.00
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1 pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureMetasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1
$320.00
Metasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1 pictureMetasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0
$49.99
Metasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0 picture
