two stage timer circuit ?
Postby chancer » Tue May 15, 2012 2:57 am
im trying to design a timing circuit that will flash a light. i believe i can just use 555s? i want the light to flash for x amount of seconds then stay off for y amount of minutes then flash again etc over and over until power removed. am i able to use 2 small pots to control x and y ? am having trouble figuring how to connect 2 555s (or 3 for the flashing or pulses to the light?) Seems simple but any help would be great
chancer
Re: two stage timer circuit ?
Postby pebe » Thu May 17, 2012 10:16 am
You can do flashing controlled with 2 pots, plus pulsing, with 2 x 555s or a single 556.
Do you want a circuit?
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger
$99.00
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger  pictureMSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR
MSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR pictureMSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 pictureMSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x
$750.00
MSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x picture
