two stage timer circuit ?
Postby chancer » Tue May 15, 2012 2:57 am
im trying to design a timing circuit that will flash a light. i believe i can just use 555s? i want the light to flash for x amount of seconds then stay off for y amount of minutes then flash again etc over and over until power removed. am i able to use 2 small pots to control x and y ? am having trouble figuring how to connect 2 555s (or 3 for the flashing or pulses to the light?) Seems simple but any help would be great
chancer
Re: two stage timer circuit ?
Postby pebe » Thu May 17, 2012 10:16 am
You can do flashing controlled with 2 pots, plus pulsing, with 2 x 555s or a single 556.
Do you want a circuit?
4/0 AWG GAUGE Copper Battery Cable Power Wire Car, Inverter, RV, Solar
$110.95
4/0 AWG GAUGE Copper Battery Cable Power Wire Car,  Inverter, RV, Solar  pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA pictureHoymiles HM-300N Grid Support Utility Interactive Inverter Microinverter
$39.97
Hoymiles HM-300N Grid Support Utility Interactive Inverter Microinverter pictureATV320U22M2C IN STOCK inverter ship by UPS/ US Free TAX
$302.76
ATV320U22M2C  IN STOCK inverter ship by UPS/ US Free TAX picture
