ques. about woltage .
Postby rabso57 » Tue Dec 25, 2012 11:31 am
if we have 2 series resistance ,the first takes like 30% of the voltage do the 70 % remaining percent of the voltage must go to the second voltage or it can take only 20% and the remaing 50 % goes back to the supply ?
rabso57
Re: ques. about woltage .
Postby I_Daniel » Wed Dec 26, 2012 9:55 am
This reply may seem rude but may I suggest that you first study Ohms Law.
Postby pebe » Wed Dec 26, 2012 10:02 am
Further to I_Daniel's reply to you, I would add the following.
This question has nothing to do with circuits, so you should have posted it in the 'newbies' section.
That said, if you apply a voltage to two resistors in series, the same current will flow through both of them. So from Ohm’s Law, if one resistor has 30% of the voltage developed across it, then the other one [u]must[/u] have the other 70% developed across it.
Here is a tutorial on Ohm’s Law that you may find helpful.
http://www.allaboutcircuits.com/vol_1/chpt_5/2.html
FLUKE VERSIV 2 MAINFRAME + FI-1000 KIT🛜 | FI2-7000 | NEVER USED (2 AVAILABLE)✨
$1500.00
FLUKE VERSIV 2 MAINFRAME + FI-1000 KIT🛜 | FI2-7000 | NEVER USED  (2 AVAILABLE)✨ pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
NI National Instruments 778643-01 Front Rackmount Kit for PXI - 8 Slot Mainframe pictureNational Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED
$225.00
National Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED picture
