ques. about woltage .
Postby rabso57 » Tue Dec 25, 2012 11:31 am
if we have 2 series resistance ,the first takes like 30% of the voltage do the 70 % remaining percent of the voltage must go to the second voltage or it can take only 20% and the remaing 50 % goes back to the supply ?
rabso57
Re: ques. about woltage .
Postby I_Daniel » Wed Dec 26, 2012 9:55 am
This reply may seem rude but may I suggest that you first study Ohms Law.
Postby pebe » Wed Dec 26, 2012 10:02 am
Further to I_Daniel's reply to you, I would add the following.
This question has nothing to do with circuits, so you should have posted it in the 'newbies' section.
That said, if you apply a voltage to two resistors in series, the same current will flow through both of them. So from Ohm’s Law, if one resistor has 30% of the voltage developed across it, then the other one [u]must[/u] have the other 70% developed across it.
Here is a tutorial on Ohm’s Law that you may find helpful.
http://www.allaboutcircuits.com/vol_1/chpt_5/2.html
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureBelden 5200 ue 2 Conductor 16 AWG 428 feet.
$45.00
Belden 5200 ue  2 Conductor  16 AWG      428 feet. pictureCarol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID **100 ft.**
$109.74
Carol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID  **100 ft.**   pictureSchneider Electric 19091 Distribution Terminal Block NG125 New NFP (4pcs)
$280.85
