Motion detector with led bulb
Postby nando » Sun Feb 17, 2013 3:05 am
I have an outdoor security motion detector, since I replaced the incandescent bulb with an LED bulb, it does not work properly.
What would I have to do, to the detector to be able to use LED bulbs? Is it due to load?
Thanks in advance
Fernando
nando
Re: Motion detector with led bulb
Postby pebe » Sun Feb 17, 2013 4:14 am
More information is needed. Is the LED the same voltage as the original lamp? Is the polarity correct?
Postby nando » Sun Feb 17, 2013 6:09 pm
The LED bulb is a 115 v a/c same as incandescent bulb. Of course, the led is 15W where the incandescent bulb is 75w.
I think I need a rely controlled detector as opposed to scr
nando
Plaud NotePin S AI Voice Recorder, 64GB Flash, with 4 Accessories
$85.00
Plaud NotePin S AI Voice Recorder, 64GB Flash, with 4 Accessories picture***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureC15 6NZ High Hp Flash Files
C15 6NZ High Hp Flash Files picturePensky Marten Flash Point Apparatus Petroleum testing Closed cup
$277.38
