Motion detector with led bulb
Postby nando » Sun Feb 17, 2013 3:05 am
I have an outdoor security motion detector, since I replaced the incandescent bulb with an LED bulb, it does not work properly.
What would I have to do, to the detector to be able to use LED bulbs? Is it due to load?
Thanks in advance
Fernando
nando
Re: Motion detector with led bulb
Postby pebe » Sun Feb 17, 2013 4:14 am
More information is needed. Is the LED the same voltage as the original lamp? Is the polarity correct?
Postby nando » Sun Feb 17, 2013 6:09 pm
The LED bulb is a 115 v a/c same as incandescent bulb. Of course, the led is 15W where the incandescent bulb is 75w.
I think I need a rely controlled detector as opposed to scr
nando
$149.00
$565.00
Ultrasonic Hardness Testercan ltrasonic contact impedance method to measure vari pictureTOA Corporation ZM-104A Impedance Meter
$248.99
TOA Corporation ZM-104A Impedance Meter pictureSOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK
$799.99
