Solenoid Alarm Clock in Series -- Voltage Problems
Postby EDDGroupAlpha » Thu May 09, 2013 6:42 pm
We are trying to put a solenoid into series with an alarm clock, in order to go off when the voltage jumps from the alarm going off. However, the voltage varies too much and does not reach a high enough current to power the solenoid.
We used a multi-meter to measure out the range and goes at the highest to around 1.5V. The voltage varies with the pitch of the alarm. When the alarm is not going off, the solenoid is not active. We are actually on an ac voltage, but the Alarm Clock is converting the ac current.
We are looking into this, but it is more than a little confusing. We were thinking that we could amplify the signal, and then use a diode, to keep it from exceeding the max the Solenoid can take (5V).
Transistor as An Amplifier (links)
http://www.st-andrews.ac.uk/~www_pa/Sco ... page1.html
The datasheet for the solenoid can be found here.
https://www.sparkfun.com/products/11015
[b]***Any information on how we could attempt to fix this would be appreciated and all used information will be cited along with relevant posts. ***[/b]
EDDGroupAlpha
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200
$22.45
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200 pictureSolenoid Valve Coil 24V 26W Fit For 0501337052-24V Replacement 0501337052
$43.17
Solenoid Valve Coil 24V 26W Fit For 0501337052-24V Replacement 0501337052 pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureSolenoid Replacement for Dentsply SPS Cavitron Gen 131, 132, 136, and 137 models
$175.00
Solenoid Replacement for Dentsply SPS Cavitron Gen 131, 132, 136, and 137 models picture
