Automatic temperature controller
Postby MrP » Sun May 19, 2013 10:14 am
Hello!
I'm having some trouble analysing this automatic temperature controller circuit. Can you please give me some indications? Thank you so much!
[img]http://i39.tinypic.com/rtfd3b.jpg[/img]
How can I find the resistor RA value to impose a 45ºC temperature on resistor R5?
When switches I1 and I2 are open, how can I find the current that will start to heat the resistor R5 and the power dissipated?
And how can I find the same current with only one of the switches open?
I just need some advice to analyse this. Thank you so, so much!
MrP
MEANWELL RSP-1000-24 24VDC 40A 100-240VAC Switching Power Supply
$85.00
MEANWELL RSP-1000-24 24VDC 40A 100-240VAC Switching Power Supply pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY picturePower Supply with Bracket 4500-PS
$60.00
Power Supply with Bracket 4500-PS pictureMean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs
Mean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs picture
