Automatic temperature controller
Postby MrP » Sun May 19, 2013 10:14 am
Hello!
I'm having some trouble analysing this automatic temperature controller circuit. Can you please give me some indications? Thank you so much!
[img]http://i39.tinypic.com/rtfd3b.jpg[/img]
How can I find the resistor RA value to impose a 45ºC temperature on resistor R5?
When switches I1 and I2 are open, how can I find the current that will start to heat the resistor R5 and the power dissipated?
And how can I find the same current with only one of the switches open?
I just need some advice to analyse this. Thank you so, so much!
MrP
$16.79
EEPROM BIOS USB Programmer CH341A + SOIC8 Clip + 1.8V Adapter + SOIC8 Ad Hot pictureREVELPROG-IS SERIAL FLASH & EEPROM PROGRAMMER (1.8V - 5V + ISP, USB)
$161.00
REVELPROG-IS SERIAL FLASH & EEPROM PROGRAMMER (1.8V - 5V + ISP, USB) picture49PCS/pack Car Eeprom IC Chips Kits 24xxx 25xxx 93xxx 95xxx SOP8 TSSOP8
$46.20
49PCS/pack Car Eeprom IC Chips Kits 24xxx 25xxx 93xxx 95xxx SOP8 TSSOP8 pictureEEPROM BIOS USB Programmer CH341A + SOIC8 SOP8 Test Clip + 1.8V Adapter + SOIC8
$27.99
EEPROM BIOS USB Programmer CH341A + SOIC8 SOP8 Test Clip + 1.8V Adapter + SOIC8 picture
