delayed follow up input circuit?
Postby loka » Thu Jun 06, 2013 4:30 pm
Hi, I am new to the forum and have limited knowledge on electrical circuits and need some help on who to achieve probably a simple task.
I have a controller device with several push buttons. What I want to achieve is on every button pressed (except say button A), one specific button, button A, to be activated milliseconds (1/60 sec) after initial button press. All buttons including button A shares a common ground. Same A button activation should be achieved when two or three buttons are pressed at the same time. Also, I want this A button follow up function to be disabled and enabled easily (maybe by physical switch or by a combination of buttons pressed while powering controller up.
can this be done with radioshack parts with simple programing?
Thank you.
loka
Re: delayed follow up input circuit?
Postby pebe » Sat Jun 15, 2013 6:53 am
I have a couple of questions:
1. What is the maximum number of buttons are involved, including A?
2. How much current do they have to pass? AC or DC?
3. What voltage is there across each button when it is not being pressed? ie. what voltage has to be switched?
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture
