delayed follow up input circuit?
Postby loka » Thu Jun 06, 2013 4:30 pm
Hi, I am new to the forum and have limited knowledge on electrical circuits and need some help on who to achieve probably a simple task.
I have a controller device with several push buttons. What I want to achieve is on every button pressed (except say button A), one specific button, button A, to be activated milliseconds (1/60 sec) after initial button press. All buttons including button A shares a common ground. Same A button activation should be achieved when two or three buttons are pressed at the same time. Also, I want this A button follow up function to be disabled and enabled easily (maybe by physical switch or by a combination of buttons pressed while powering controller up.
can this be done with radioshack parts with simple programing?
Thank you.
loka
Re: delayed follow up input circuit?
Postby pebe » Sat Jun 15, 2013 6:53 am
I have a couple of questions:
1. What is the maximum number of buttons are involved, including A?
2. How much current do they have to pass? AC or DC?
3. What voltage is there across each button when it is not being pressed? ie. what voltage has to be switched?
Southwire Romex SIMpull 10/3 50 ft NM-B Copper Wire w/Ground 63948422 NEW
$99.95
Southwire Romex SIMpull 10/3 50 ft NM-B Copper Wire w/Ground 63948422 NEW pictureWestward 19Ye37 Weldingcable, Epdm, 2/0Awg, 600V, Red, 25Ft
$224.99
Westward 19Ye37 Weldingcable, Epdm, 2/0Awg, 600V, Red, 25Ft pictureSchneider Electric 19091 Distribution Terminal Block NG125 New NFP (4pcs)
$280.85
Schneider Electric 19091 Distribution Terminal Block NG125 New NFP (4pcs) pictureCarol C0562a Communication Cable, 8 C, Gray, Pvc, 100 Ft.
$426.99
Carol C0562a Communication Cable, 8 C, Gray, Pvc, 100 Ft. picture
