MOSEF
MOSEF
Postby tigger03 » Mon Apr 28, 2014 12:47 pm
I am attempting to build the power MOSEF interfacing circuit (page 8 of http://www.picaxe.com/docs/picaxe_manual3.pdf) and was wondering if the NTE2985 MOSEFT Logic Level N-Ch Enhancement Mode High Speed Switch would serve the same purpose as the IRL520. Thank you very much for your help!
tigger03
Re: MOSEF
Postby pebe » Fri May 02, 2014 1:09 pm
They are both logic level FETs, ie. they will turn fully on with 5V gate-source voltage.
So the NTE will be a replacement if the maximum drain voltage and current you require do not exceed 60V and 30A.
Rockville RCS80-1 60 Watt 70v Commercial/Restaurant Amplifier/Bluetooth Receiver
$61.87
Rockville RCS80-1 60 Watt 70v Commercial/Restaurant Amplifier/Bluetooth Receiver pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER pictureHoneywell R7861A1023 Honeywell Flame Amplifier
$249.99
Honeywell R7861A1023 Honeywell Flame Amplifier picture
