MOSEF
MOSEF
Postby tigger03 » Mon Apr 28, 2014 12:47 pm
Hello,
I am attempting to build the power MOSEF interfacing circuit (page 8 of http://www.picaxe.com/docs/picaxe_manual3.pdf) and was wondering if the NTE2985 MOSEFT Logic Level N-Ch Enhancement Mode High Speed Switch would serve the same purpose as the IRL520. Thank you very much for your help!
tigger03
Re: MOSEF
Postby pebe » Fri May 02, 2014 1:09 pm
They are both logic level FETs, ie. they will turn fully on with 5V gate-source voltage.
So the NTE will be a replacement if the maximum drain voltage and current you require do not exceed 60V and 30A.
$139.00
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureCordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner
$54.90
Cordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner pictureIdex / Systec Vacuum Pump 9000-1926 bench tested and GUARANTEED to work.
$245.00
Idex / Systec Vacuum Pump 9000-1926 bench tested and GUARANTEED to work. picture
