Discharge protection for Lithium Cells
Postby legostar » Sat Dec 13, 2014 2:20 am
Hi I'm quite new to electronics but I'm trying to learn.
I want to create a discharge protection for my lithium cells using a IRL3714 MOSFET.
The MOSFET in this circuit open up at around 1.5V, is there anyway to make it open up at 2.5-3.2V instead.
I've tried connecting a zener diode in series to the gate, I found out that a ZPD2.7 zener raised it to open up at around 3.7V. I don't know if this is the correct way to do it, or how to find the right zener diode for 2.5-3.2V
Guess you could also do a resistor voltage divider, but guess that would not turn off when the MOSFET is closed and keep draining the battery.
So I'm a bit clueless how to drop the voltage the correct way, without continuous battery drain.
Any help would be very much appreciated.
Thanks.
/Henrik
[img]http://i60.tinypic.com/inab84.png[/img]
legostar
Re: Discharge protection for Lithium Cells
Postby pebe » Sat Dec 13, 2014 2:54 pm
I use lithium 18650 'protected' cells that have a PCB containing a protection circuit fitted to the base of each cell. They prevent damage to the cell from any form of misuse. You can buy the separate PCBs on Ebay, here:
http://www.ebay.co.uk/itm/4-pcs-PCB-for ... 2344051d8d
Check it out because they may be of use to you.
Edit: BTW, is the battery switched and should the battery voltage be 3.7V; not 3V?
Rockville RCS80-1 60 Watt 70v Commercial/Restaurant Amplifier/Bluetooth Receiver
$61.87
Rockville RCS80-1 60 Watt 70v Commercial/Restaurant Amplifier/Bluetooth Receiver pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER picture# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier
$649.00
# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER picture
