Discharge protection for Lithium Cells
Postby legostar » Sat Dec 13, 2014 2:20 am
Hi I'm quite new to electronics but I'm trying to learn.
I want to create a discharge protection for my lithium cells using a IRL3714 MOSFET.
The MOSFET in this circuit open up at around 1.5V, is there anyway to make it open up at 2.5-3.2V instead.
I've tried connecting a zener diode in series to the gate, I found out that a ZPD2.7 zener raised it to open up at around 3.7V. I don't know if this is the correct way to do it, or how to find the right zener diode for 2.5-3.2V
Guess you could also do a resistor voltage divider, but guess that would not turn off when the MOSFET is closed and keep draining the battery.
So I'm a bit clueless how to drop the voltage the correct way, without continuous battery drain.
Any help would be very much appreciated.
Thanks.
/Henrik
[img]http://i60.tinypic.com/inab84.png[/img]
legostar
Re: Discharge protection for Lithium Cells
Postby pebe » Sat Dec 13, 2014 2:54 pm
I use lithium 18650 'protected' cells that have a PCB containing a protection circuit fitted to the base of each cell. They prevent damage to the cell from any form of misuse. You can buy the separate PCBs on Ebay, here:
http://www.ebay.co.uk/itm/4-pcs-PCB-for ... 2344051d8d
Check it out because they may be of use to you.
Edit: BTW, is the battery switched and should the battery voltage be 3.7V; not 3V?
Plaud NotePin S AI Voice Recorder, 64GB Flash, with 4 Accessories
$85.00
Plaud NotePin S AI Voice Recorder, 64GB Flash, with 4 Accessories picture***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureC15 6NZ High Hp Flash Files
C15 6NZ High Hp Flash Files pictureUVEX FLASH SALE Safety Goggles Eyeglasses SW 06 - NO LENSES - Rx ABLE
$428.00
UVEX FLASH SALE Safety Goggles Eyeglasses SW 06 - NO LENSES - Rx ABLE picture
