Printed circuit board to be needed
Postby fina » Wed Oct 21, 2015 9:14 am
I have sent some PCB designs to factories for prototyping. The price, however, varies greatly. Some ask 200USD for a four-layer 5cm*10cm PCB prototyping. While some only ask for 50USD. I assume that there are differences between these two factories. However, I could not find the differences. Could I ask for some advice here?
fina
Re: Printed circuit board to be needed
Postby pebe » Thu Oct 22, 2015 8:06 am
If the 50USD quote is from China it ill be because their labor costs are lower.
Postby bwetman » Tue Oct 27, 2015 11:19 am
"For more information about PCB you can visit at [http://www.epectec.com/pcb/data/url] and also can visit at Soldertools"
pcb needed.jpg (19.11 KiB) Viewed 44373 times
bwetman
Postby circuitboardready » Thu Mar 24, 2016 3:44 am
Even both factories located in China, there are also that big price different. It's quite depends what sort of techni or quality you are looking for. USD 50 is normal price for sampling.
circuitboardready
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureAPT 112-03-800 REV K High Voltage Solenoid Driver Board Applied Process Tech PCB
APT 112-03-800 REV K High Voltage Solenoid Driver Board Applied Process Tech PCB pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 picture
