automatic door opening chicken house
Postby fdear » Sun Dec 13, 2015 7:44 pm
to open and close once day with adjustable times i need the polarity to change for 12v-24v reverse polarity motor .I wondered would you list the required components and describe how to wire it +diagrams. I hope to use 240v + tranformer down to 12v or12v battery +time clock 0-60 second cheers frank.
fdear
Re: automatic door opening chicken house
Postby pebe » Sun Dec 20, 2015 5:47 pm
Have you decided what tímer you will use?
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC picture
