automatic door opening chicken house
Postby fdear » Sun Dec 13, 2015 7:44 pm
to open and close once day with adjustable times i need the polarity to change for 12v-24v reverse polarity motor .I wondered would you list the required components and describe how to wire it +diagrams. I hope to use 240v + tranformer down to 12v or12v battery +time clock 0-60 second cheers frank.
fdear
Re: automatic door opening chicken house
Postby pebe » Sun Dec 20, 2015 5:47 pm
Have you decided what tímer you will use?
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureClarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT
$16.90
Clarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT pictureCavitron power potentiometer for Gen 131, 132, 136, 137
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
