Electronics
Electronics
Postby cconly » Thu Aug 18, 2011 6:17 am
Electronics is the branch of science, engineering and technology that deals with electrical circuits involving active electrical components such as vacuum tubes, transistors, diodes and integrated circuits. The nonlinear behaviour of these components and their ability to control electron flows makes amplification of weak signals possible and is usually applied to information and signal processing. Similarly, the ability of electronic devices to act as switches makes digital information processing possible.
Electronics is distinct from electrical and electro-mechanical science and technology, which deals with the generation, distribution, switching, storage and conversion of electrical energy to and from other energy forms using wires, motors, generators, batteries, switches, relays, transformers, resistors and other passive components. This distinction started around 1906 with the invention by Lee De Forest of the triode, which made electrical amplification of weak radio signals and audio signals possible with a non-mechanical device. Until 1950 this field was called "radio technology" because its principal application was the design and theory of radio transmitters, receivers and vacuum tubes.
Today, most electronic devices use semiconductor components to perform electron control. The study of semiconductor devices and related technology is considered a branch of solid state physics, whereas the design and construction of electronic circuits to solve practical problems come under electronics engineering This article focuses on engineering aspects of electronics.
Electronic devices and componentsAn electronic component is any physical entity in an electronic system used to affect the electrons or their associated fields in a desired manner consistent with the intended function of the electronic system. Components are generally intended to be connected together, usually by being soldered to a printed circuit board (PCB), to create an electronic circuit with a particular function (for example an amplifier, radio receiver, or oscillator). Components may be packaged singly or in more complex groups as integrated circuits. Some common electronic components are capacitors, inductors, resistors, diodes, transistors, etc. Components are often categorized as active (e.g. transistors and thyristors) or passive (e.g. resistors and capacitors).
cconly
Postby clark » Thu Aug 18, 2011 7:35 am
With the development of transistor, electronic devices shrink tremendously
clark
Postby Mike Paul » Sat Nov 19, 2011 11:47 am
Hey guys,
Thank you for your valuable tips about the electronic items, Electronic items are made of dangerous substances. For example, many LCD screens in televisions contain mercury in their panels. Cathode rays in the monitors of computers and some televisions contain lead. Other than these, nickel, cadmium and lithium are also found in electronic items.
Thanks a lot
Mike Paul
Mike Paul
Re: Electronics
Postby aadambell » Fri Jan 13, 2012 9:16 am
as the technology is growing and advancing ahead the electronic parts being going shrinked but in the same time providing multitasking with many features.
aadambell
Johnson Controls MSNCE25660 Metasys Network Control Engine
$100.00
Johnson Controls MSNCE25660 Metasys Network Control Engine pictureJohnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A
$1900.00
Johnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A pictureMetasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0
$49.99
Metasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0 pictureJohnson Controls M4-CGM09090-0 Metasys 18-Point General Purpose Controller
Johnson Controls M4-CGM09090-0 Metasys 18-Point General Purpose Controller picture
