measuring current
measuring current
Postby kripzzz » Fri Jan 06, 2012 7:13 pm
i need an IC to sense current of range 0-8 micro ampere of resolution 9 nano ampere.. it is then required to measure that current..
kripzzz
Re: measuring current
Postby Thomas W » Sun Jan 08, 2012 3:36 pm
Is there sense resistor in the circuit you want to measure on? Or how are you going to interface to the circuit under test?
Thomas W
Postby kripzzz » Sun Jan 08, 2012 5:36 pm
[quote="Thomas W"]Is there sense resistor in the circuit you want to measure on? Or how are you going to interface to the circuit under test?[/quote]
i'm going interface using an I2C.. actually i'm not sure if to use a current sensor or anything else..
kripzzz
Postby Thomas W » Sun Jan 08, 2012 9:24 pm
I'm thinking an opamp with high input impedance, with the output connected to an A/D converter with I2C interface.
What kind of circuit or component do you want to measure the current in?
Thomas W
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable picture351302170065 Thermocouple Heavy Duty - 72 Inch -
$50.00
351302170065 Thermocouple Heavy Duty - 72 Inch -  picturePico Technology USB TC-08 Thermocouple Data Logger (Model PP222) - New/Open Box
$325.00
Pico Technology USB TC-08 Thermocouple Data Logger (Model PP222) - New/Open Box pictureCooking Performance Group Thermocouple 351302170058
$45.50
Cooking Performance Group Thermocouple 351302170058 picture
