cut out switch
cut out switch
Postby janathan » Mon Apr 07, 2014 6:22 pm
Hello, i am looking for a CUT OUT switch for my fridge.
I want a switch, which when the electricity goes out shuts off and will remain shut off until i manually turn it on, so the fridge will not turn on automatically when the electricity is restored.
i tried to search online for this cut out switch but did not find anything suitable for a fridge (or TV or AC).
Can anyone please suggest anything?
janathan
Re: cut out switch
Postby pebe » Wed Apr 09, 2014 12:46 pm
I could not find one, either. But you could make one using a relay like this - the only extras needed would be a push button and a case.
http://www.ebay.co.uk/itm/Coil-Power-Re ... 23384d4578
Re: cut out switch
Postby alexjordon27 » Thu Apr 17, 2014 11:45 am
Hello there,
I am new in this forum. I love to play with electricity and circuits. So i hope i will be fun over here on this forum.
Thanks & Regards
Alex
alexjordon27
Re: cut out switch
Postby janathan » Wed Apr 23, 2014 10:38 pm
[quote="pebe"]I could not find one, either. But you could make one using a relay like this - the only extras needed would be a push button and a case.
http://www.ebay.co.uk/itm/Coil-Power-Re ... 23384d4578[/quote]
Thank you very much, I told my dad and he is making one now from the kind of relay you described.
appreciate your help :)
janathan
Re: cut out switch
Postby KMoffett » Thu May 08, 2014 6:59 pm
A feature you might want to add...a warning light at the fridge, to indicate that the relay must be reset after the power comes back. see attached.
Fridge Cutout.gif (4.15 KiB) Viewed 16160 times
Oops. I changed the connections of the lamp/power/fridge on the upper relay contacts.
Re: cut out switch
Postby ronitbajaj » Tue Aug 26, 2014 6:11 am
Thanks buddies to sharing these useful information with us.
Philips LED Tubes | LED Ceiling Panels | Buy Philips LED Bulbs
ronitbajaj
$16.98
Lot of 2 - Littelfuse TECCOR - S4055M - SCR. 55Amp 400V, TO-218.  Thyristor New picture5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA
$118.84
SCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
