How to determine frequency?
Postby abbot » Tue Mar 10, 2015 12:29 pm
I have being working on oscillators, when I was analyzing an issue I found that the oscillators is generating more frequency than tuned (5.8kHz instead 5kHZ).
This frequency is connected to IN1 / CLK1 of CPLD. Now I want to know, whether this effects the functionality of CPLD but it seems our module is functionally ok.
I have two questions here :
1.how the clock frequency of CPLD is determined, is it based on the required speed we need ??
2.What happens if the frequency exceeds the specified ??
Thanks in advance..
abbot
Re: How to determine frequency?
Postby pebe » Sat Mar 21, 2015 7:57 am
Look up the data sheet for the CPLD to find the permitted frequency range for the oscillator. This is the nominal range, and some samples may work beyond those limits - but that cannot be guaranteed.
You may select any frequency you like provided is within limits.
Postby jocelynholmes » Mon Aug 10, 2015 3:52 am
4 Easy Way to determine frequency
1.f = V / λ
2.Example: λ = 322 nm
322 nm x (1 m / 10^9 nm) = 3.22 x 10^-7 m = 0.000000322 m
3.Divide the velocity of the wave, V, but the wavelength converted into meters, λ, in order to find the frequency, f.
4.After completing the previous step, you will have completed your calculation for the frequency of the wave. Write your answer in Hertz, Hz, which is the unit for frequency.
jocelynholmes
Postby bwetman » Mon Oct 19, 2015 7:28 am
using "f = V / λ" you can find the frequency.
where, v=velocity and
λ=wavelength.
bwetman
Postby PradeepKumar » Mon May 29, 2017 12:15 pm
Frequency is the number of wave cycles or revolutions per second. The Formula for period (T) in terms of frequency is given by,
f = 1/T or
If we consider any wave in terms of velocity and wavelength the Frequency Formula is given by,
f = V / lamda
PradeepKumar
🌟Vintage KISTLER’s Donuts out of Akron Ohio. 🍩 tray with faux pastry display
🌟Vintage KISTLER’s Donuts out of Akron Ohio. 🍩 tray with faux pastry display pictureVintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer
$162.41
Vintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer picture300+ Vintage National CMOS Semiconductor Lot - See Description
$75.00
300+ Vintage National  CMOS Semiconductor Lot - See Description pictureVintage LAM Systems Desktop PC Intel Pentium Floppy CD DVD Retro Computer READ
$180.00
Vintage LAM Systems Desktop PC Intel Pentium Floppy CD DVD Retro Computer READ picture
