Reverse Polarity (after power stops)
Postby pebe » Fri Apr 29, 2011 1:52 pm
It depends on your timer. If it uses a relay to drive the load, then no problem. You will need a diode only if there is a warning about using it with an inductive load.
But if you want to be sure, connect a 1N4001 across the coil. Connect the diode with its cathode to positive side of the relay output.
DPCO is Double Pole Change Over
DPDT is .DP....Double Throw
DP2W is DP....Two Way
They are all the same.
Best regards to a Yankish and his dad from a 'sassenach' in Scotland :lol:
Previous
$64.95
$82.88
$349.99
ASUS Z8PE-D18 Dual Xeon Server Motherboard 2x E5620 CPU 144GB RAM 12x12GB LGA136 pictureIntel SE7520JR2 Server Motherboard, Dual PGA604 XEON, SCSI LVD
$299.00
Intel SE7520JR2 Server Motherboard, Dual PGA604 XEON, SCSI LVD picture
