Reverse Polarity (after power stops)
Postby pebe » Fri Apr 29, 2011 1:52 pm
It depends on your timer. If it uses a relay to drive the load, then no problem. You will need a diode only if there is a warning about using it with an inductive load.
But if you want to be sure, connect a 1N4001 across the coil. Connect the diode with its cathode to positive side of the relay output.
DPCO is Double Pole Change Over
DPDT is .DP....Double Throw
DP2W is DP....Two Way
They are all the same.
Best regards to a Yankish and his dad from a 'sassenach' in Scotland :lol:
Previous
AlphaSmart NEO 2 Portable Word Processor Keyboard - Tested Working pictureGE IC693PWR321 Series 90-30 Power Supply Module
$1188.00
GE IC693PWR321 Series 90-30 Power Supply Module  pictureHobart 15SDS-3/8 Soft Dicing Set Food Processor Attachment 00-914391
$437.50
Hobart 15SDS-3/8 Soft Dicing Set Food Processor Attachment 00-914391 pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit picture
