MOSFET switch, open circuit with capacitor?
Postby Gabsbiz » Sat Jul 25, 2015 6:21 am
NEWBIE ALERT
I'm trying to use a MOSFET as a switch. I've been successful when using an arduino because it provides both a negative to close and positive to open.
I want to use a MOSFET switch without needing an arduino. Getting the switch to close is simple enough, by providing power, but how do I open the circuit again? Simply removing power does not close the circuit.
I thought about using a small capacitor that would provide a tiny amount of positive after battery power was removed, but my research left me confused and doubtful this would work.
Any tips or ideas?
Cheers,
Gabriel
Gabsbiz
Re: MOSFET switch, open circuit with capacitor?
Postby KMoffett » Sat Jul 25, 2015 6:04 pm
What's the load you're switching on and off? Switching what voltage and current? Which MOSFET?
If you're doing low-side switching with an N-MOSFET and just removing power from the gate, there is still a charge on the gate that keeps the MOSFET in conduction. If so, just add a 10K resistor between the gate and source to discharge the internal gate-source capacitance.
$13.49
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureServus Super Dielectric Lineman Overshoes Mens Size 7 Brand New But Read L
$54.95
Servus Super Dielectric Lineman Overshoes Mens Size 7 Brand New But  Read  L pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L picture
