MOSFET switch, open circuit with capacitor?
Postby Gabsbiz » Sat Jul 25, 2015 6:21 am
NEWBIE ALERT
I'm trying to use a MOSFET as a switch. I've been successful when using an arduino because it provides both a negative to close and positive to open.
I want to use a MOSFET switch without needing an arduino. Getting the switch to close is simple enough, by providing power, but how do I open the circuit again? Simply removing power does not close the circuit.
I thought about using a small capacitor that would provide a tiny amount of positive after battery power was removed, but my research left me confused and doubtful this would work.
Any tips or ideas?
Cheers,
Gabriel
Gabsbiz
Re: MOSFET switch, open circuit with capacitor?
Postby KMoffett » Sat Jul 25, 2015 6:04 pm
What's the load you're switching on and off? Switching what voltage and current? Which MOSFET?
If you're doing low-side switching with an N-MOSFET and just removing power from the gate, there is still a charge on the gate that keeps the MOSFET in conduction. If so, just add a 10K resistor between the gate and source to discharge the internal gate-source capacitance.
Samsung CA4-10M Ultrasound Probe
$550.00
Samsung CA4-10M Ultrasound Probe pictureSamsung AM018ANMDCH VRF Indoor Unit Ducted 18,000 BTU - NEW
$850.00
Samsung AM018ANMDCH VRF Indoor Unit Ducted 18,000 BTU - NEW picture2022 SAMSUNG CA2-8AD CONVEX ARRAY ULTRASOUND TRANSDUCER PROBE TESTED
$1300.00
2022 SAMSUNG CA2-8AD CONVEX ARRAY ULTRASOUND TRANSDUCER PROBE TESTED pictureSamsung AM007ANMDCH VRF Slim Ducted Indoor Unit 7,000 BTU - NEW
$775.00
Samsung AM007ANMDCH VRF Slim Ducted Indoor Unit 7,000 BTU - NEW picture
